I want to make a 9 Volt NiMH battery charger, can someone help me
I want to make a portable battery charger for 9Volt NiMH batteries, but i don't know where to start or even what chip to use.
Thanks for any help
RE: I want to make a 9 Volt NiMH battery charger, can someone help me
Maxim makes a couple of IC's you will find convenient to build your battery charger arround.  You will need to specify a couple of components, but if you use there suggested circuit and provide the suggested voltage and power requirements, it will work fine, and I have packaged the circuit very compactly before.
The MAX712/713 can be found at:
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1666
