Titanium cladding
Titanium cladding
Titanium cladding
Please give me info,
There are face Heat exchanger will be machining, on the surface face there are cladding with material Titanium and thickness 5 mm and maksimum cutting 0.5 mm. I wory the machining causing crack on the cladding, and what material and type ( Cutting insert) used for cutting that Titanium material.
