Delta or Wye Motor for Phase Converter
Would a delta or wye motor provide for better voltage stability in a rotory phase converter in the 25 hp. range? I realize an AC-DC-AC inverter would be best, but not cost effective.
Thanks for your input.
RE: Delta or Wye Motor for Phase Converter
Suggestion: Visit
http://www.thomasregister.com
and type Converters: Phase under Product or Service, which will return 60 companies to approach to
Hello JBurgess
I am not sure if the fact the motor is Star or Delta would actually makes any difference for its performance.
Motor internal electrical/magnetic losses will govern its performance.The internal connection should not make a meaningfull difference.
GusD
Suggestion: Generically, the delta connection cancells triplen harmonics no matter if it is within transformer or motor stator. This means that the harmonics will not propagate to the rotor via the iron magnetic circuits.
