Wire Mesh/Screening Representation
I would like any input in drawing wire mesh/screening, even
though we tend to represent the part without it, can it be done relatively quick with a special technique?
RE: Wire Mesh/Screening Representation
If you're talking about drawing mode, the answer is (after creating the view):
View --> Disp Mode --> Wireframe --> Done
and it's quick and easy.
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
Create a sketched cosmetic feature with crosshatching in your part or assembly.  Modify the cross hatching on your drawing by retrieving "aluminum" and then adjust the spacing and angle untill it looks right.
Andy
I wish I can delete my previous posting. For some reason I was thinking about a "Wireframe" view.
im4cad
Thanks atlarson I used the technique and I received the result I needed
