OLEDB provider for sql server timeout expires
1)There are no syntax errors
2)Im using the newest OLEDB driver for sql server. NOT ODBC
The discussion you suggested doesnt really apply to my situation. I still tried those fixes in vain but no luck.
3) Im not actually selecting *, i just kind of threw that in there to cut down on the lenght of text i had to paste in there. I am using dynamic parameters. Im testing with a large query right now. Something odd is that it chokes on a query that only takes 35 seconds. the one before it takes over a minute and works fine. when i cut out the 35 second one and use the next query which takes even longer. it works!
Here is the query that times out. I know this is the exact code that runs because i output it before the recordset attempts to open (thats where the error is):
THE CODE
________________________
Sql = "SET NOCOUNT ON " Sql = "SELECT vmv_lab_code, variable_name as variable, method_code as method, unit_code as unit from tvar2 where vmv_lab_code in (" & strVMVLAB_CODES & ") order by vmv_lab_code" sql = replace(sql, "'", "''") sql = "select * from openquery(MON, '" & sql & "');" 'Sql = "SELECT vmv_code from tvar1 where vmv_code in (" & strVMVLAB_CODES & ")" Response.Write("
") response.Write(sql) Response.Write("
") Cmd.CommandText = Sql Cmd.CommandTimeout = 99999 set rsVMV = server.CreateObject ("ADODB.Recordset") rsVMV.CursorLocation = adUseClient rsVMV.Open Cmd, , adOpenDynamic
THE ACTUAL STATEMENT THAT RUNS:
________________________________
select * from openquery(MONCTON1, 'SELECT vmv_lab_code, variable_name as variable, method_code as method, unit_code as unit from tvar2 where vmv_lab_code in (''02011-02'',''02041-02'',''02042-80'',''02042-81'',''02061-02'',''02061-80'',''02061-81'',''02065-81'',''02073-02'',''02078-81'',''06107-02'',''06154-02'',''06581-02'',''07110-02'',''07315-02'',''07601-01'',''07601-02'',''08102-81'',''09105-02'',''09106-02'',''10101-02'',''10110-02'',''102078-02'',''102079-02'',''102080-02'',''102081-02'',''102082-02'',''10301-02'',''10301-80'',''11103-02'',''12102-02'',''12107-02'',''13302-02'',''13305-02'',''14102-02'',''15413-02'',''16304-02'',''16309-02'',''17205-02'',''17209-02'',''19103-02'',''20110-02'',''25304-02'',''26304-02'',''26305-02'',''29305-02'',''29306-02'',''30304-02'',''48302-02'',''80315-02'',''82302-01'',''82302-02'',''97001-81'',''T00410-02'',''T107-02'',''T108-02'',''T109-02'',''T110-02'',''T111-02'',''T112-02'',''T113-02'',''T114-02'',''T115-02'',''T116-02'',''T118-02'',''T120-02'',''T121-02'',''T122-02'',''T123-02'',''T125-02'',''T126-02'',''T127-02'',''T132-02'') order by vmv_lab_code');
dave
