Macro Programming Newbie Question
We are new users of UG. We're using UG-NX. I've recorded simple a simple macro and have some questions.
1. Is there a macro programming langauge which supplements the recorder?
2. What is the best source of documentation for the macro language?
3. Can the macro langauge take user input - other than the actual recorded keystrokes, mouse-licks, etc..
4. Are there any other API's, besides the Macro language and the 'c'-based API?
RE: Macro Programming Newbie Question
p.s. try to avoid those mouse-licks - quite unsanitary! :)
There is no real language behind the macros. It is strictly a record of what keystrokes you pressed. If you know what you are doing, you can take a .syslog file and turn it into a macro. You can also edit the macro file to make minor changes to what the original macro did.
UG help files are the best source for documentation for any of the UG programming tools, macros, GRIP or UG/Open API.
There is a user entry and user pause under the Macro recorder that will allow you to input values and such will the maro is in playback mode.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Any Comments?
EDS has admitted that GRIP is: ""mature". Not offering anything new, but great at what it does provide." This is from a UG developer.
If your needs are along geometry manipulation, use the PAI. If you only need to manipulate attributes, then GRIP will work.
Ben Loosli
Ingersoll-Rand
I have a task to automate our drawing formats across all of our different projects. We all use the same format, but each group uses different markings (Stamps). The GRIP program would also add part attributes, apply layer catagory names, and import the format and stamps as patterns.
I've reviewed other methods like seed parts, macros and template files. Macros work but cause errors during playback and would probably have to be re-created at each UG upgrade. Seed parts and templates work but I don't think they work with a top down assembly approach. I haven't spent a lot of time with these, so I could be wrong.
I think GRIP is the best course to take, but I'm being told that GRIP will not be supported and we shouldn't spend time developing GRIP or training on using GRIP.
Templates work best in a master-model approach, separate drawing file from the model/assembly file.
If you are new to UG customization, I would go with the API over GRIP. They both can do what you have outlined.
I think there is too much legacy GRIP out there for EDS to drop its support. I will agree that they will not enhance it, but I think they will make sure it still works, at least for the next few years.
Ben Loosli
Ingersoll-Rand
