Liquid bubbler design?
Hello all,
I have a question concerning the design of a "bubbler", i.e., a vessel full of a liquid through which a gas is bubbled to pick up some liquid vapor.  In my research, I have successfully used a two-stage bubbler system with nitrogen gas flowing through acetone liquid.  I was able to determine (via a light absorption measurement) that my system easily saturated the nitrogen with acetone vapor - which is exactly what I wanted.
Now, I am trying to build a bubbler system for use with air passing through toluene.  Here, too, I need to saturate the air with toluene vapor.  I cannot measure the toluene concentration downstream of the bubbler (toluene does not absorb light in any wavelength for which a source is available in our lab).  Right now, I just assume that the system is saturated - as some other researchers have done.  But that's not really rigorous and scientifically accurate.  What I'm looking for is some sort of criteria - perhaps based on residence time in the bubbler, bubble area, etc. - that would let me judge whether I'm saturating or not.
Does anything like that exist?  I appreciate any advice you can offer.
Best regards,
--M. Tsurikov
RE: Liquid bubbler design?
tsurikov, Instead of trying to just calculate theoretical saturation levels, why don't you install a side stream field mounted analytical instrument such as G.C. or Mass Spec.. This will allow you to do real time quality control and allow you to build a data base on saturation level vs. residence time vs sparger design.
saxon
