Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thank you again! I can't tell you how much I and my company appreciate what you've done! I love this place!..."
Geography
Maffei (Aerospace)
28 Mar 01 8:20
I need some information on welding 430 (or 430F)
stainless steel to 304 or 316.
Is it possible using TIG, beam or laser welding?
What are the concerns when welding these materials
together if any?
What filler rod is recommneded?
Any other information would be greatly appreciated
Thank You,
Vince Maffei
Helpful Member!  matt3mason (Aerospace)
1 Apr 01 12:29
317 filler is use when welding two differents tipe of stainless steel  the equipment use is  regular TIG  with ARGON,  to clean the parts  wire brushes  and  related tool should be  made of ss also to avoid any contamination.
wktaylor (Aeronautics)
5 Oct 01 9:22
Try the AWS WHB Series Hdbks... or go to the ASM website and check-out books on SSTLs - Wil Taylor
vti (Aerospace)
5 Oct 01 13:18
We weld this combination quite often. The low carbon grades (304L or 316L) create a better weld. We use only 430. We do not use 430F for welds. I know other companies use TIG and Laser, but we use only E.B. We do not use fillers but keep gaps to a minimum of .002". Parts also have to be very clean. We do not weld inhouse but use E.B. Industries. (http://www.ebindustries.com/). We manufacture solenoid valves for primarily aerospace applications from this combination.
Close Box
Join Eng-Tips® Today!
Join Us             Close
