Static Load Test on Timber Piles
Looking for any advice/previous experiences in performing a "simple and inexpensive" staic load test on timber piles. The piles are supporting a log stringer bridge, 20m span w/ six piles/abutment. There is an interest to replace the superstructure (log stringers & timber deck) and there is relatively no information on the existing piles or soil conditions.
My intent is to try and come up w/ a procedure to perform a static load test on one of the piles, then using an applicable FofS, design a replacement superstructure.
Any advice on on the most feasible method of testing one pile and not using any additional piles as reaction points would be most welcome, thx.
RE: Static Load Test on Timber Piles
D 1143 shows several methods for loading and testing piles.
Of course, it would be a good idea to do a boring and see the soil conditions. Still, unless you have the depths of the wood piles, it might be a mute point. Older wood piles might be 45 to 60 ft long; newer ones likely shorter due to availability.
Let us know if you get any more details.
