AutoCad 2000 - Changing Pin Settings?? (for printing)
I know how to do it in Cad 14, but can't figure it out in 2000.  My prints are faded in some areas depending on the layer and I don't want to go thru and change the layers just to print, and some blocks would have to be exploded which won't work.
If not pin settings, maybe a monochrome setting??
Anybody??
Hank
RE: AutoCad 2000 - Changing Pin Settings?? (for printing)
You're getting grey-scale representations of color.  Use monchrome or set all pens to black
I know...how do I do that in 2000??
In your plot dialog there is a drop down list for plot style tables. From this list select monochrome.
This will change all pen colors to black.
regards
sc
That did it!  Thanks!  That's bugged me since I switched from 14 to 2000!!
