Does voodoo3 works with proe??
I have an voodoo3 AGP video card (16MB), and I installed the proe 2000i, in my computer, I have a PIII 700MHz with 32MB RAM...I Know that I can run the proe but I have a problem....when I want to make a part, I can“t see the Datums, sometimes I can see them but when I want to put a line or do something, they are already gone!...I think that this is a problem with my video card, but I not sure.
RE: Does voodoo3 works with proe??
May it help u/
turn off blend in color control box/
Evgeni Filippov Russia S-Petersburg
Mail to enfilipo@lomo.sp.ru
This is a limitation of the video card.  Pro/E has a compatibility mode for graphics.  Under config.pro, use the 'graphics' option and set the value to 'win32_gdi'.  This is how to do it in 2000i2, and should be the same in 2000i.  If you do not have this value to select from, try different modes until you get one to work (you have to retart Pro/E everytime you change this option).
Recneps
