sql server timeouts on remote server query
Im running 3 distributed sql querys on a linked server (sits in a different province) through an asp page. Both databases are Sql Server
the select staments both kind of look like the following:
select * from openquery(MON, 'SELECT vmv_lab_code, variable_name as variable, method_code as method, unit_code as unit from tvar2 where vmv_lab_code in (''02011'',''T132-02'') order by vmv_lab_code');
WHen setting up my linked server i set all timeouts to 0.
Timeouts on the remote sever itself are set high enough (if that even makes a difference)
WHen i run the first two queries in sql query analyzer, together they run in about 1:48.
However, when running the queries in my asp page, when it gets to the second statement the page times out on the recordset.open.
shows this error statement:
Microsoft OLE DB Provider for SQL Server error '80040e31'
Timeout expired
/envirodat_moncton/root/main/en/generatePivot.asp, line 124
I really dont get it because in addition, my connection timeout and commandtimeout properties are set to 99999.
Again, when i run these statments in query analyzer they work fine.
however they timeout when running in my asp code.
Any ideas
thanks,
dave
RE: sql server timeouts on remote server query
Hi dave,
I thought you don't have index on "vmv_lab_code" field. just put an index on this field and try again
