End Of Month
End Of Month
End Of Month
i need Some Code to Find if its the End of the Month
and what month we are Currently on. useing the calendar Control in VB
RE: End Of Month
The end of the month can be done with something like:
If Month(myDate+1) > Month(myDate) Then
' myDate is end of month
The name of the month can be got from :
Format(myDate,"mmmm")
Using "mmmm" above will give June
Using "mmm" above will give Jun
Using "mm" above will give 06
Using "m" above will give 6
Good Luck
johnwm
RE: End Of Month
  Were is MyDate Coming from ?
 the example you provided does nothing
RE: End Of Month
I assume myDate is your date variable. If you are using the current system date, just use the Now function.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
RE: End Of Month
Public Function MonthEnd() As Boolean
Dim myDate As Date
    myDate = Date
    myDate = myDate + 11
    If Month(myDate + 1) > Month(myDate) Then
        MsgBox myDate & " is the end of the month."
        MonthEnd = True
    Else
        MonthEnd = False
    End If
End Function
This should od it for you.
Derrick
