ASME Section VIII Div 1 UG 44 & ANSI B 16.47 for A 105 Material
As per ANSI B 16.47 clause 2.6 "Ratings for CS bored welding neck flanges are based upon their hub at the welding end having thickness at least equal to that calculatedfor pipe having 40.0 KSI specified minimum yield strength."
As per ASME SEC VIII Div 1 (UG 44) if the flanges are standard design then calculation is not required so long as the allowable stress suits the tables given in the standard.
Carbon Steel Forgings A 105 does not have yield as 40.0 KSI.
Is it necessary to design flanges as per appendix 2 of ASME even for Standard (B16.47) flanges under this circumstance.
RE: ASME Section VIII Div 1 UG 44 & ANSI B 16.47 for A 105 Material
