Calculating Stresses on Inserts
Does anyone know of a calculation to utilize for estimating the strength of inserts in plastics. The inserts I am speaking of are the ones to be thermally or ultrasonically installed. I want to know if I have to take into account the thread stress area or not. Seems like many variables to account for, looking for a formal way of analyzing. Any suggestions?
RE: Calculating Stresses on Inserts
defining the basis of these inserts.
Contact them first and go from there.
They must have many references in their
sales pitches.
I would expect the manufacturer would have
the information that you are requesting.
Have no idea if you are talking about a press
fit application or is the insert threaded on
the od? If so I would use that as the basis
for the plastic pull out force to be calculated.
If the loads mentioned above are combined, your stresses may have to be calculated by using the Morh circle concept.
DS
Normally you don't have to consider thread stress area since the inserts are much stronger than the polymer/insert interface. Most inserts have surface features to promote physical interlocking. This prevents easy calculation/analysis. A way to start is to calculate the interface shear area A:
A = π D L
where
π = 3.141 592 654
D = insert outer diameter
L = insert height
Then, the axial force resistance F is:
F = A τi
where
τi = the interface strength
The interface strength usually is unknown, but could be approximated using the polymer shear strength τp.
brass for the insert
what is the grade and material of the bolts?
and also the torque values you wish to impose?
There is a section in Machineries Handbook
that shows how to calculate the strength of
internal threads or how long they should be
in contact for different strength materials.
I assume you are using the thread locking
type insert keensert or solid inserts rather
than heli-coil style inserts. I also assume
the length is 2 times the diameter and you
are only concerned about the static calculations
and that the parts are not subjected to much
of a dynamic type loading. Everyone should
test their product for liability reasons as I
assume the strength of plastic is quite
variable as well as the surrounding structure
from design to design. I assume there is
enough material around the keensert to ensure
it will not fail from that condition. I would
expect material to exceed a circle at least one
and one half times keensert od.
