ADXL202 accelerometer to PIC16F877 to RS232 C code
I am trying to determine the best way to connect an Analog Devices ADXL202 2 axis accelerometer to a PIC16F877 40 pin device then transmit the relevent data to the PC via RS232.
I will be using CCS PIC C compiler and so hints (or ideally some code) would be very gratefully received.
