Diesel Engines and V-belts?
I'm looking for comments (good or bad) relating to powering a liquid ring vacuum pump with a diesle engine using v-belts. Is the choice of v-belts a wise decision or is here a more practical way?
RE: Diesel Engines and V-belts?
If you need more information, call me at 641-423-9363 with more details about your application. Good Luck, Paul Juhnke, Maintenance Engineering Services.
