concrete foundation
concrete foundation
Someone I know poured an 8' heigh foundation and now wants to go to nine feet. Any suggestions or recomendations on how to properly bond/secure the new 1'concrete section to the existing foundation? Any reference material covering this problem?
John
John
RE: concrete foundation
You break the existing concrete in the area where you are going to add more concrete. You leave the reinforcement intact. Clean up. Then you add reinforcement and tie them to the existing. Finally you pour new concrete over.
This is probably easier than using chemically bonded rebars.
One opinion from me. Good luck.
"happycamper" posted a question JOINING NEW CONCRETE TO OLD in the Concrete Engineering forum, and Ron,JAE, Qshake etc great guys did a very good job answering that.
Visit there too as you wait for better responses to your specific question
Are the rebars sticking out? Will u have enough development lenghths/laps for fixing reinforcement.
If its yes, than u can roughen the area of concrete that is to receive new concrete by say 25mm to 50mm. Clean by sand blasting or wire brush. The surface should be dry and free of standing water. Apply Sikadur 32 ( Sika Product ) by brush and place fresh concrete while it is still tacky.
Riz
Great idea. Never used Sika 32 before, a nice new adventure.
Seems a good solution if you have enough reinforcement sticking out from existing part. I will definitely use that.
I am just curious, what shall we do in case of no reinfocement sticking out, since in most cases, especially in metal structures, you dont have reinforcement projecting out at a finished level.
Equally interested.
IJR
Gita
