Who checks the z-equation?
Chapter 10 of the code requires that the following be satisfied: z <= 175 (interior) or z<= 145 (exterior), where z = f_s (d_c A)^1/3.
Meeting this requirement can be tricky in a real building. For example, for a structural slab on grade which spans, say, between grade beams, but is built directly on grade, the maximum bar spacing with 3" cover is on the order of 4 inches.
I do not believe the CRSI design handbook designs meet the z-equations. Does everyone else violate the requirement to arrive at reasonable designs?
RE: Who checks the z-equation?
