Need balun on microstrip antenna ??
RE: Need balun on microstrip antenna ??
You won't need a balun for a microstrip antenna.
A microstrip antenna is seperated to the
signal path and a groundplane, as it is part
of the microstrip definition. Therefore You
need no balun (balanced-unbalanced-converter).
Only an impedance match like a lambda/4-line.
Chris
