Tool life Taylor extended Equation
hi, im a mechanical engineer.
I am going to study a finish bohring operation using a single insert toolholder. The initial conditions are:
depht of cut=0,3 mm (mean diameter 26 mm)
cutting speed=160m/min
feed=240mm/min
Part: Rod made of sintered steel. HRC 30 core and surface.
Insert: Kennametal CCMT 060208 LF KT315 (cermet coated)
Before trying, i would like to know if the Taylor extended Equation can be applied to this case.
I know that i am simplifying too much but i have read one experimental study about Taylor extended equation and would like to compare it with your knowledge.
Thanks a lot.
feed=240mm/min
Thanks a lot.
RE: Tool life Taylor extended Equation
I imagine they did help in getting us to the moon and building Hoover Dam.
It all depends on the objective and the desired accuracy of your study. The Taylor equation is a very rough approximation of reality. It is more suitable for low cutting speeds and for “old” tool materials. I would recommend the use of the first metal cutting law instead.
Viktor
http://viktorastakhov.tripod.com
Robert Setree
www.advanced-grinding.com
