Multiple Cantilever Beams
I have a situation where I have centrifigal blower being supported by three structural beams that are cantilevered to a certain distance. I need to find the natural frequency of the system so that I can check to make sure that the blower does not run at that same frequecy. How do I calculated the natural frequency of all the beams?
Anyones input would be appreciated.
Thank you, Mike
Thank you, Mike
RE: Multiple Cantilever Beams
M
f=1/(2*pi)*sqrt(k/m)
f is in Hz, all the other units need to be correct.
If this is in the ballpark of your running speed then go and look Blevins up, or do an FE model.
Cheers
Greg Locock
