Set a point load on the surface of a curve
I'm trying to set a point load on the surface of a curve. is this possible or am I have some sort of operator malfuntion. Any help would be greatly appreciated
RE: Set a point load on the surface of a curve
If you're trying to put a load on a point along a curve you'll first have to make a point on that curve to select as a point load.
To apply a load to a curve which is a boundary to a surface you'll have to delete the surface, add the point on the boundary to the surface and then create the surface again and add the load onto the point.
Make sure that the elements near this point have nodes on the point if you're autoGEMing the surface, if they don't try deleting the surface again, splitting the curve at the point you've gcreated and creating the surface again.
If you want to add a load at a point somewhere in a surface, you'll have to split the surface into more surfaces, so that there's a point on the surface you can pick to add the load to.
