BRUSHLESS DC MOTORS
BRUSHLESS DC MOTORS
BRUSHLESS DC MOTORS
I would like to know from anyone that has hands on experience with the brushless DC drives.If you have used these motors,How reliable are they?
What type of system was it used on?Pump,Blower,Conveyor?
Did you use anything with HP rates of 200 to 400 HP ?
Thank you all for help.
GusD
RE: BRUSHLESS DC MOTORS
We have used one burshless DC system that was 400HP.  We have many installed that are 30HP and less.  To my knowledge we had not trouble with the motor (400HP) in the 6+ years of operation.  Upon startup there were some drive problems, but that was mainly related power electronic problems in the drive and not any sort of control problem.
300 hp
using it for a pump appl
no problems
brushless DC is the way to go
Now when your talking Brushless DC Drives, are you refering to like drives for Brushless servo motors, stepper motors, or ac sync motors?...they are all brushless dc.
Cameron Anderson - Sales & Applications Engineer
Aerotech, Inc. - www.aerotech.com
"Dedicated to the Science of Motion"
Hi servocam
Sync motors may or may not have brushes.You are right  about the others.As for the Brushless DC I was refering to is a motor where the rotating element has magnets and the Stator (in this case a field) has the windings.These motors are powered from Inverters not much different that any VFD applic.Th Inverter action provides the DC needed to power motor.As I understand from the literature,they have speed/torque curve characteristics superior to FluxVector Drives.I tried a website for one manufacturer and I was intrigued by the technology.We have most of the other motor types made but none like these.
Thank you Servocam (try POWERTEC website)
GusD
Thanx. Fam. w/ Powertec. Just not that fam. with that type of motor technology your refering too.
GusD,
The application where we used the 400HP was also Powertec.  Have had mixed success with the smaller drives, but little problem with the motors.  For variable speed, high torque applications they are nice.  The efficiency is good also due to the PM rotor providing the required magnetization.
