How to model limit the maximum force taken by a spring?
SAP2000 is able to model supports as springs. But does SAP2000 allow the failure of a spring?
For an example, if the spring is under tension and subjected to a force larger than its capacity, the spring breaks and the force previously taken by it will transfer to its neighbouring springs.
How can these springs be modelled???
RE: How to model limit the maximum force taken by a spring?
With previous versions, you would have to use the Plastic1 nllink and input yield strength and post yield strength info.
