Nonlinear Compression Only gti file
*TITLE 'EXNL01 - HIGHLY NONLINEAR COMPRESSION-ONLY TEST'
STRUDL 'EXNL01' 'HIGHLY NONLINEAR COMPRESSION-ONLY TEST'
$* ** PROBLEM DESCRIPTION: Sample problem for Nonlinear Analysis.
PRINT GEN OFF
UNITS FEET POUNDS DEGREES
GEN 2 JOI ID 1 100 X -8.916,-1 Y -14.5
MOD 19 ID 1 Y 0.97
JOINT COORD
1001 -2.83 4.907
1002 2.83 4.907
GEN 2 JOINTS CYL Z ID 21 100 R 6.083 1 TH 180 LZ 0 OFFSET 1001
MOD 6 ID 1 TH -10
GEN 2 JOI CYL Z ID 28 100 R 11.75 1 TH 115 LZ 0
MOD 11 ID 1 TH -5
GEN 2 JOI CYL Z ID 40 100 R 6.083 1 TH 50 LZ 0 OFFSET 1002
MOD 5 ID 1 TH -10
GEN 2 JOI ID 46 100 X 8.916 1 Y 3.937
MOD 19 ID 1 Y -0.97
TYPE PLANE FRAME
GEN 64 MEMBS ID 1 1 FROM 1 1 TO 2 1
TYPE PLANE TRUSS
GEN 63 MEMBS ID 101 1 FROM 102 1 TO 2 1
STATUS SUPPORT JOI 1 65 102 TO 164
JOINT RELEASES
1 65 MOM Z
DELETIONS
JOINTS 101 165
ADDITIONS
INACTIVE JOINTS 1001 1002
UNITS INCHES
PRINT JOINT COORDINATES
UNITS INCHES
CONSTANTS
E 3.6E6 MEMBERS 1 TO 64
E 1.E6 MEMBERS 101 TO 163
MEMBER DIMENSIONS
1 TO 64 RECT B 12 H 10
MEMBER PROP PRIS
101 TO 120 144 TO 163 AX 139.68
121 TO 143 AX 152.88
PLOT PROJECTION
LOADING 1 'UNIFORM LOAD OF 1 KIP/FT'
MEMBER LOADS
21 TO 44 FORCE Y GLO UNIW -83.33
LOADING 2 'TEXT LOAD TO MATCH ANSYS RESULTS'
JOINT LOADS
21 TO 45 FORCE Y -713.2 $ = 17830 LBS
LOAD LIST 2
NONLINEAR EFFECTS
COMPRESSION ONLY MEMBERS 101 TO 163
MAXIMUM NUMBER OF CYCLES 1
CONVERGENCE TOLERANCE EQUIL 0.00001
NONLINEAR ANALYSIS REDUCE BAND
LIST LOADS DISPL
NONLINEAR ANALYSIS CONT
LIST LOADS DISPL
NONLINEAR ANALYSIS CONTINUE
MAXIMUM NUMBER OF CYCLES 20
OUTPUT DECIMAL 4
OUTPUT ORDERED
LIST DISPLACEMENTS
LIST LOADS
LIST REACTIONS
LIST FORCES
CONVERGENCE TOLERANCE DISPL 0.00001
MAXIMUM NUMBER OF CYCLES 25
NONLINEAR ANALYSIS
LIST DISPLACEMENTS
LIST LOADS
LIST REACTIONS
LIST FORCES
FINISH
PRINT GEN OFF
MOD 19 ID 1 Y 0.97
JOINT COORD
1001 -2.83 4.907
1002 2.83 4.907
MOD 6 ID 1 TH -10
MOD 11 ID 1 TH -5
MOD 5 ID 1 TH -10
MOD 19 ID 1 Y -0.97
TYPE PLANE FRAME
TYPE PLANE TRUSS
JOINT RELEASES
1 65 MOM Z
DELETIONS
JOINTS 101 165
ADDITIONS
UNITS INCHES
UNITS INCHES
CONSTANTS
MEMBER DIMENSIONS
MEMBER PROP PRIS
PLOT PROJECTION
MEMBER LOADS
JOINT LOADS
LOAD LIST 2
NONLINEAR EFFECTS
LIST LOADS DISPL
LIST LOADS DISPL
OUTPUT DECIMAL 4
OUTPUT ORDERED
LIST DISPLACEMENTS
LIST LOADS
LIST REACTIONS
LIST FORCES
NONLINEAR ANALYSIS
LIST DISPLACEMENTS
LIST LOADS
LIST REACTIONS
LIST FORCES
FINISH
