Layers in "Quick Select" not in alphabetical order
I cannot find a way to get the layers in the quick select dialog box under object properties to list in alphabetical order. I checked the "maxsort" system variable and the value is 300 which is much higher than the number of layers in my drawing. It is very difficult to try and pick objects by layer name when they are all over the place. It makes "quick select" become
"S L O W S E L E C T". Any help is appreciated.
Rickc
Rickc
RE: Layers in "Quick Select" not in alphabetical order
it's an Autodesk-bug...
I wait on solutions too
Lothar
Win NT4.0 (SP6),
ACAD 2000i (SP2), ADT 3.0 (SP3),
ACAD 2002, ADT 3.3,
OCÈ 5200
Just a thought
Jamie
Good luck and let us know of any progress you make in this area.
Cheers
I'm sorry, I can't reproduce Your solutions. In AC2002 the Layers are never in alphabetical order, when using "Qselect" ->Layer, like Rickc posted. Maybe Autodesk is helpless too:
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2898844&linkID=2475323
Regards Lothar
Win NT4.0(SP6),2000(SP3)
AC 2000i(SP2), ADT 3.0(SP3),
AC 2002, ADT 3.3,
AC 2004, ADT 2004
Now we all know a little bit more, and alas are no better off because of it.
