Kollmorgen drive failure(On power up?)
We used Kollmorgen Servo drives model CE06200 and CE06250 (same model with different current properties) on a job a few years ago. Serial number between 99A180-99A195..
Since then, sometimes (pretty often) when we have to shut power down, there is one or more of the drives that never work again on power up (both model numbers do it). There is about 20 drives for this job, and each of them failed at least once since the machine is running (few years).
It looks like a power supply failure, nothing happens on the drive, as if there was no power. The last time we had to shut down, 2 of the drives did it. We dont see any particular operation that is made during the shut down period that could cause this kind of problem. We send the drives for repair, but Kollmorgen send new/repaired drives and does not give us any hint of what happenned to the drives.
Any of you experienced similar reliability problems with this drive model/brand ?
What do you suggest ?
Any hints would be welcome.
Frederik
Frederik
RE: Kollmorgen drive failure(On power up?)
since the common denominator of these drives is your power supply, i suggest to rent a power quality monitoring instrument... make sure to cover the weekend wherein the demand for power is low...
this is a good and cheap way to start and can eliminate the source of trouble step by step..
goodluck,
dydt
If you are using fast acting semiconductor type fuses that are appropriately sized, the fuse should open first.
What failed on the drives.Do they all fail for the same reason?The failure mode may be indicative of the root cause.
GusD
The above suggestions for line conditioning could help, but don't you think Kollmorgen would ask why they keep failing? After all, you say that what, ~20 some drives have failed.
When in distribution, I sold many different Mfgs. drives and I have had problems like this. Sometimes something the customer was doing, other times if was a problem with the Mfgs. product.
I would press Kollmorgen on what exactly is failing and start from there.
Cameron Anderson - Sales & Applications Engineer
Aerotech, Inc. - www.aerotech.com
"Dedicated to the Science of Motion"
