Converting Pro/E Files to SW - Any Tips?
Using SW2003 SP1.0 (also tried SP3.0 ) and Pro/E 2000i2 with latest patch.
We have recently discovered that some of our conversions via .step are not coming into SW accurately. A good number of them convert badly as well, leaving us with twanged parts.
I was wondering if anyone has stumbled across a combination of settings that our Pro/E users should be using, and our SW user's should be using to get an accurate conversion?
Any information is helpful. Thanks a bunch!
Dianna
Dianna
RE: Converting Pro/E Files to SW - Any Tips?
Anything you can do to ratchet up the accuracy of your trim curves going out should help. I believe there are options you can insert into your config.pro for this. You end up with larger files, but is file size more important than accuracy of information?
You may wish to also pose this query on the Pro/E forum.
And I'm available for consultation,
but remember your way in is also my way out
Dianna
