size units for AutoShape objects (inch or cm?)
I use scaled drawings in Excel. Sometimes the Autoshape object properties are in inches and at other times they are in cm.
How can I force Excel to use cm as the size units for an AutoShape Object?
Many thanks.
Many thanks.
RE: size units for AutoShape objects (inch or cm?)
When I load Excel from VB the default Autoshape units are inches. No Regional settings.
When I load Excel from the desktop it first loads my Personal.xls which has regional settings and so uses cm for the Autoshape size.
Cheers,
Joerd
