Member Login
HANDLE
PASSWORD
Remember Me
Forgot Password?
E-mail*
Handle
Password
Verify P'word
Partner With Us!
Partner Button
(Download This Button Today!)
Member Feedback
"...I have answered some questions and have gotten answers for my questions. Anywhere you can do this on one page helps tremendously..."
Geography
 How to translate from vertical motion to rotational
Rampower (Mechanical)
28 May 03 15:27
Imagine, if you will...
A valve which is typically actuated via vertical displacement (downward stroke)...
However, I have managed a means to activate the valve via rotational motion.
I was hoping to get a few ideas from the forum on how to translate the vertical motion (I have to deal with this as a prerequisite to design is retrofit to existing product)to rotational.
I need only rotate a 3/8 diameter shaft 50 - 60 degrees...
Any thoughts?
RamPower made RamTough
Eng-Tips Forums is Member Supported. Click Here to donate.
Mandrake22 (Mechanical)
28 May 03 15:39
Rack and pinion.
Linkage connecting a lever arm on your rotational element to the linear element.
Scipio (Mechanical)
28 May 03 19:08
I agree with Mandrake22, from the sounds of it you're just describing a fairly typical rack & pinion linear actuator for quarter-turn ball valves.  We use them all the time for emergency shutdown valves.  Readily available for pretty much anyone who makes rotary control valves - Fisher, Bettis, Flowserve, come to mind.  Here's a link to one of flowserve's designs (this one's pneumatic piston operated with a spring return).
http://www.flowserve.com/valves/automation/pages/heavy_duty.stm
snubengr (Mechanical)
30 May 03 11:50
We have designed and built several of our own scotch-yoke actuators for specialty sub-sea applications.  They really are not complicated (in their simplest form anyways) yet are very reliable and rugged.  Sounds to me like what you need would be available from any of a number of vendors.  We have used Bettis in the past for standard applications and had good results.
Denande
Helpful Member!Cockroach (Mechanical)
30 May 03 18:19
Yeah, I see what you're up to.
I would use a trick utilized with downhole equipment such as packer or wireline apparatus in the oilfield.  Cut a closed J Slot into the stem of the valve, and have a pair of lugs "cam" rotational motion as the stem rises or falls.
Alternatively, you should be able to simplify rotational motion by cutting a helix into the stem and have rotational motion as a consequence to a pair of lugs riding in the slot.  This would be more cost effective and easily machinable with a mill.  In addition, you get a compact design without the need of a bulky Scotch Yoke mechanism to translate linear to rotational motion.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
mackerm (Automotive)
31 May 03 5:02
It's a problem Watt struggled with, but which Peaucellier solved..  Do a google search for "Peaucellier Cell"
ccw (Nuclear)
1 Jun 03 0:25
The best approach may be influenced by other dimensional and actuator force constraints.
I have an application where I use essentially Cockroach's alternative (helix) to obtain 60 degree rotation from linear input.  The rotation output axis is coincident with the line of action of the linear input.
The pitch of the helix for a given 60 degree rotation determines the linear stroke.  The peak force required for the linear input stroke varies inversely with the stroke required and directly with the output torque required.
chicopee (Mechanical)
1 Jun 03 11:44
From your description of the problem one solution can be from a crank, a link and a slider.  The crank would rotate 360 degrees and when properly to the slider by a link you would get the linear reciprocal motion from which the 3/8" rod actuated by the slider  can rotate back and forth 50- 60 degrees.
4 Jun 03 12:59
Just got back in the office...
Gentlemen (and ladies as applicable),
Thanks for all your input! Cockroach, it was scary reading your response. While out of the office I had our prototype shop start fab'g parts with virtually the same methodology / design as you describe. The valve will still have slight vertical motion (a function of the helical slot slope?) however primary motion will be rotational.
Thanks again for the inputs...
Rampower
Start A New Thread
Promoting, selling, recruiting and student posting
are not allowed in the forums.
Posting Policies
LINK TO THIS FORUM!
(Add Stickiness To Your Site By Linking To This Professionally Managed Technical Forum)
TITLE: Mechanical engineering other topics Forum at Eng-Tips
URL: http://www.eng-tips.com/threadminder.cfm?pid=404
DESCRIPTION: Mechanical engineering other topics technical support forum and mutual help system for engineering professionals. Selling and recruiting forbidden.
