Wind Turbine Bearing Load
Does anyone know how to calculate the bearing load on a wind turbine?  The gyro loads are the ones I have difficulty calculating.  If there is a gyro or wind turbine design reference (book and/or web) that you could recommend?
Thanks.
RE: Wind Turbine Bearing Load
Maybe look into the loads placed on fixed wing propellers, only in reverse (minus the weight of the aircraft lift).
