Concrete Intersecting Beams Joint ->Cold or not?
I would like your advise on this problem:
One RC beam perpendicular to another, same level, one acts as a support for the other. Does the joint needs to be constructed as a monolothical pour? What happens if poured separately? Does longitudinal rebar sticking out into other beam sufficient to take shear? Let me know what you think. Thanks.
RE: Concrete Intersecting Beams Joint ->Cold or not?
If for some reason you cannot achieve this, then a cold joint at an intersection can be dealt with. You simply have a shear friction situation and your reinforcing, above and beyond what is needed for flexure, must be added across the joint to satisfy the shear friction capacity. The joint should be keyed or otherwise intentionally roughened.
See Chapter 11 in the ACI code under Shear Friction for the method.
But I would avoid the situation if you can.
