External Spline Machining
Please could somebody suggest the best latest technology to machine an external spline. The material is steel, I have no further information to spec as yet. dia. 45 mm / length  30 mm / 10 mm clear runout at end of spline before next larger dia. The spline detail has not yet been supplied to me, however it has a vee form and is straight.
Would we use an external ring type broach, hob, or CNC mill on a lathe or machining centre.
I would have to machine approx. 30 parts per hour, and the machine needs to have good operator interface and cover all health and safety / ergonomic req's.
RE: External Spline Machining
I have only seen hobbing of splines done on a horizontal milling machine.
What is the material being splined?  If it is steel, this will be a slow process.  Therefore you likely will want to build a special machine tool which will accommodate multiple shafts to be splined simultaneously.
Jesus is THE life,
Leonard
Have you considered rolling the splines?
30 pieces per hour for the sizes you indicated would be a walk in the park for spline rolling. Superior finish, increased surface hardness and increased productivity are all reasons my first choice would be spline rolling.
I agree, folowing further investigation spline rolling seems to be the best option.
There's also a cold extrusion option you might want to consider.  Spline rolling is pretty much an industry standard, but there are a couple "rules of thumb" that might impact its applicability to your part:
Module = 1.5 or less
Must be an involute spline
pressure angle = 30 degrees or greater
There's also a slight difference in flank geometry between the flank that was leading during forming and the one that was trailing.
If you can't live with these (not a problem in most applications), cold extrusion may be a better option.  No limit to pressure angle, no process-induced requirement for involute form, and the module limits are somewhere beyond 4.0 (at 130mm pitch dia - probably still in the 2.0 range for parts such as your shaft).
Here are a couple links:
builder of specialized axial forming machines:
http://www.felss.de/felssEnglish/siteMaschinenAxialform.html?topID=30&navID=3&navID2=8&allID=3
Cold forging production house working with external splines on shorter parts:
http://www.mfccorp.com
Good luck!
