Thermal barrier
Thermal barrier
we have cylindrical shell whose temp is 500 oc .it has support .we want to reduce heat transfer to this support by introducing thermal barrier .
what material you suggest which will reduce heat tranfer at the same time has crushing strength to with stand load .
pl help
pl help
RE: Thermal barrier
It may give you some ideas.
