pro program..... resources?
i have a limited and basic knowledge and understanding of pro program can anyone suggest any links or sites.  I want to get fully comprehensive with this part of pro engineer?
Many thanks
RE: pro program..... resources?
This may be a dumb question, but, did you read the help file section on Pro-Program?
procadman2
Proe Design & Admin
Mechanical & Aerospace
"You can't build a reputation on something you haven't done."
H Ford
You're kidding right!
PTC documentation has got to be worst I have seen. Missing information, incomplete instructions, out-of-date "read this First" guides, etc.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
I like your quote...
I didn't realize you were running wildfire.
The only books I've seen so far have little on Pro-Program.
I have a tutorial dated R13 or R14.  The programming part has changed very little.
If you have a fax number I can send it to you if you like.
procadman2
Proe Design & Admin
H Ford
Skiddy,
Not sure if you will find this helpful, but I have had this come up as part of a search on Google:
Introduction to Optimization Excel to Pro/ENGINEER through Pro/PROGRAM (http://engr.bd.psu.edu/METBD_306_p/METBD_306_p/assign/lab%2010_02.pdf)
Try also searching through some of the resources listed in the FAQ PTC Pro/ENGINEER and Pro/MECHANICA internet resources FAQ554-468.
Good luck!
Best regards,
Matthew Ian Loew
We run a lot of Pro-E models indirectly from Excel using Pro-Program, I am quite proficient in Pro-Program, and am willing to answer any questions you may have, as everybody where I work does as well.
I am trying to become an expert in this field. So any questions would help me as well no doubt.
Feel free to ask as many questions as you like.
maybe only a drafter
but the best user here!
Onlyadrafter...........
Could you give me a few details on adding family tables within pro prog?
My main assembly features one main component, which can be chosen out of 4 options.
For each of the 4 options i have pro prog working on them, therefore they are all interchangable?
But how do i go about creating a table?
Many thanks
I'm not entirely certain what you are trying to do, it sounds as though you should be using Interchange Assembly, but...
I don't think you can actually create instances within Pro-Program, but the next best thing is to use Instantiate (within Program).
When you have run Pro-Program, press 'PROGRAM' and 'INSTANTIATE' you will be prompted for a new assembly name and new part names.
This is why I don't think you are using the correct method, try these and if no luck, give a more detailed explanation.
hope this is of some use.
but the best user at this company!
