shock friction
shock friction
Another recent thread mentioned the problem of friction in shocks due to the side loading imparted on the shock when a coil over spring buckles under compression. I have been curious about how big of an effect this is (I would like to see some numbers). The main problem that I see w/ quantifying this is that I don't know what would happen to a damper dyno if you tried to run it w/ a spring mounted w/ the shock -- maybe people do it all the time. I know a lot of racecar teams are spending a lot of R&D $$$ to try and reduce all forms of suspension friction (shocks included) and I assume this is even why some F1 teams have gone to a torsion bar setup.
I believe that this friction can and does significantly affect the performance of the suspension, but I would like to see some numbers.
Thanks in advance,
brandon
Thanks in advance,
brandon
RE: shock friction
I can't quote numbers directly, but in the early stages of a production vehicle module design, the measured side loads were in the 1000 - 2000 N range.
A product of interest to the race car side of the industry might be the Hyperco/ICP Hydraulic Coupling Device:
www.propartsusa.net/products/hypercoil/hcd.htm
http://icpcitation.com/shockperches.htm
This devise allows the spring seat to pivot to reduce the side-load of the spring.
There is an article on this system in the April/May 2003 issue of Racetech Magazine (www.racetechmag.com).
Additionally, The following SAE International (www.sae.org) technical papers all include information on the phenomenon of side-load in springs:
2002-01-0317: The Effect of Rubber Seats on Coil Spring Force Line
2001-01-0496: Modeling of Coil Springs Using Parallel Mechanisms
2001-01-0497: Development of L-Shape Coil Spring to Reduce a Friction on the McPherson Strut Suspension System
2000-01-0101: Optimization of Force Action Line With New Spring Design on the McPherson Strut Suspension for Riding Comfort
2000-01-0727: System Modeling of a Damper Module
970100: Optimization on Mac Pherson Suspension With a Spring
960730: Approaches to Minimizing Side Force of Helical Coil Springs for Riding Comfort
940862: Side Load Springs as a Solution to Minimize Adverse Side Loads Acting on the Mcpherson Strut
For automotive damper struts, the springs can be intentionally designed to produce side-loads to minimize system friction. For damper modules, the side-load needs to be minimized.
Hope this helps.
Best regards,
Matthew Ian Loew
RE: shock friction
Thanks for the papers, I'll have a read, since I am stuck in McP strut hell at the moment. Grumble grumble.
When we get into trouble on this we strain gauge the tube so that we can measure the forces. Given the lower shock velocities and high spring loads a race car sees I imagine this is rather important. Another option, if you have the room in an SLA or double wishbone, is to terminate the shock at a ball joint, integral with the lower spring tower. This would stop the spring loading the shock in bending. I've only just thought of that, does it make sense?
Cheers
Greg Locock
RE: shock friction
I thought so. Have a look at the formulation that relates the spring seat position on the damper body to the side-load resolved at the rod-guide and piston.
____F_____
0[ [==]=========0
A B
Dimensions:
L = length between bearings
DL = length of damper body (between lower bearing and rod-guide)
X = position of F from lower bearing
BS = bearing span (between piston and rod-guide)
Forces:
A = force acting at lower bearing (assume + up)
B = force acting at upper bearing (assume + up)
F = side-load force acting at X (assume + down)
Fp = Force at piston
Frg = Force at rod-guide
Eq 1) A + B - F = 0
Eq 2) F(X) - B(L) = 0
Eq 3) F - A + Fp - Frg = 0
Eq 4) Fp + B - Frg = 0
I am too lazy to solve this right now.
Best regards,
Matthew Ian Loew
RE: shock friction
I am 99% confident it is a good idea, it just may be a bit too complex for a production car, and too long for a racer.
Actually there are endless variations possible on this, there is definitely a strong case for replacing the bottom bush on a shock with a ball joint. Might even improve micro shake.
Cheers
Greg Locock
RE: shock friction
Even with strut suspension we convert the upper pickup point to a sperical bearing.
Dave
RE: shock friction
With some modern "bearing grade" engineering plastics, it might be possible to design a high volume spherical joint at a price that might be viable.
I have recently seen some very high performance from a Bronze Filled Nylon, with mechanical and bearing properties rivaling sintered metal.
i don't want to get further into it here, as I do have a commercial interest, and this is not the place to pursue it
pat
RE: shock friction
Best regards,
Matthew Ian Loew
RE: shock friction
pat
RE: shock friction
Cheers
Greg Locock
RE: shock friction
Cheers
Greg Locock
RE: shock friction
I will do some homework and send what I have to your e-mail
pat
RE: shock friction
Almost all shocks supplied by us have spherical bearings at both ends, although it should be noted that these are outside the spring/damper sideload system and have no impact on that issue.
There is no problem with running dampers with springs on the dyno (provided the spring load plus max damping force does not overload the dyno). The spring force is a straight line (disregarding hysterisis) which can be "torn off" from the damper curves.
We have a dummy damper (linear bearings and no internals) specifically for calibrating dyno load cells against a known spring.
Pat. I would also be very interested in your plastic bearing material. What do you call "high temperatures"? some of our dampers run up to 150°C (heat soak in the pit lane being the highest temperature event). Does the material work as a liner, or is it strong enough to make entire spherical bearings? Contact PTwissell at Multimatic dot com if you wish.
PT
RE: shock friction
Actually I am a shocks engineer for 9 years, so I think I can add some comment here.
Shocks friction is an issue of vehicle ride performance especially for passenger vehicles. Currently the competitive shocks for passenger vehicles, which is normally twin-tube shocks, the friction of the shoks does not go over 50N without any side load. The test speed is important factor for measurement of the shocks, it is from 0.0003 to 0.0052 m/s which is somewhat variant between auto makers.
This case is for smooth ride oriented shocks, there I have no idea how race teams treat the friction of the shocks.
RE: shock friction
And for the springs, the idea of letting the spring twist on bearings is very good. Because when the spring is compressed, it wants to twist. Using bearings, the spring can twist very easily. By doing this, the traction of the car will improve, because the shocks can now follow the little bumps in the road, while shocks with more friction aren't able to move. and this will make the car very bumpy, especially at low speeds.
RE: shock friction
It might remove the moment created at that seat, but If we are still talking coil-overs or macPherson struts I think if one end of the spring is still on a seat affixed to the the shock body it could exert a moment (if it felt like it), unless the ball jointed spring seat could move laterally.
I picture the playground ride consisting of coil spring welded to a plate on the ground, with a kid sitting in a saddle on the free end. When the kid leans forward the seat may pivot significantly, but eventually the spring resists more translation.
RE: shock friction
You are right, the ball at the bottom does not eliminate all of the moments in the shock, if it has an integral spring seat. In practice though it does seem to improve microshake possibly because it provides very high axial stiffness and low coning and torsional rates - possible in a rubber bush, but easier in metal.
I notice Mercedes have this on their double ball joint (virtual king pin) suspension.
It would be nice to move away from coil over shock to free up the shock, but I can see no nice way of doing it with a coil spring, especially given that we normally have to protect for, but never design, a 4 wheel drive. No, we can't go to torsion springs, or lever type shock absorbers!
Cheers
Greg Locock
