ANSYS 3D magnetostatic analyis
In a 3D magnetostatic analysis of a volume, including SOURCE36 current source and singly-connected iron regions, I obtain a zero solution. I tried different values of source current and relative magnetic permeability, tried to use or not to use infinite boundary, but result is the same. As prescribed in ANSYS docs I used DSP formulation. What is my mistake?
RE: ANSYS 3D magnetostatic analyis
Thanks in advance
