Show Edge problem
Show Edge problem
Show Edge problem
Hi all
Can someone help me to show all the edges I already hide
What I did in my dwg. is: right-click on edge and click "hide edge"
thanks
RE: Show Edge problem
There was an SPR out on that. I don't think it has been repaired yet...but what SP are you using?
The only fix for your .slddrw is to reinsert the views till this SPR gets repaired.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
from the help...
"If you cannot select the hidden edges, click Tools, Options, System Options, Drawings. Make sure that the Select hidden entities check box is selected."
Then you will be able to select the hidden edges and show them.
Sanity! You're a madman!
I just spent a couple minutes playing with this.  I found it convenient to place a temporary isometric view on the drawing with all edges visible.  Then I can see what is being selected in that view, as well.  This may be helpful in determining if you are selecting the "top" edge or an underlying edge.
There's no double-lock defense; there's no chain on my door.
And I'm available for consultation,
but remember your way in is also my way out
Thanks for quick reply guys..
I am using SP3.1 the latest one
TheTick is right,he solved my problem, It's work for me...
