over centering cams - how do they work?
I work for a top aircraft manufacturer customer support division. A question i was asked about one of our business jet aircraft is "does the passenger door utilize over centering cams." I have never heard this term before.
Does anyone know what this is and could you describe how it works....examples???
thanks
Mark
thanks
Mark
RE: over centering cams - how do they work?
Your knee isn't a "cam", so the analogy only works so far as the effect goes. A cam is cylindrical, but isn't perfectly round. The cam has one (or many) knobs that, when it rotates, can push on another object.
STF
Jay
jayk@dicarinc.net
The beauty of a toggle joint or over center device is that the transverse force applied to the elements to be held in place is dramatically multiplied by the locking/unlocking force. Once locked, the unlocking motion must go back thru the centerline and the unlocking force albiet a small fraction of transverse then must ramp-up to a maximum value as it passes thru center making it very unlikely to unlock accidently even from vibration if designed correctly.
Jesus is THE life,
Leonard
