Corrupt Network Data
When sending data between client and server I'm getting corrupt results. It's easiest to see with Zip files as they identify which file has failed. I've used another PC as the server and copied filed successfully which would indicate that the problem is at the server end. I've replaced the network card on the server PC but the problem persists. In each case the server is running ME and the client Win 95.
Any clues as to what I could try next?
xAMcRx
RE: Corrupt Network Data
You might get better response on the Tek-Tips forum
TTFN
