Supports on elbow in horizontal pos'n
Can anyone please advise how I should model a support offset from an elbow in the horizontal position on Caesar?
i.e. the elbow has a welded trunnion to which the supports are fixed. Is it acceptable to use C-Nodes?
Appreciate all your expertise!
Thanks in advance.
Does anyone know whether it is possible to add sketches to these threads. Its far easier to explain the problem????
Thanks in advance.
RE: Supports on elbow in horizontal pos'n
Vertical dummy legs on bends and horizontal dummy legs on bends.
[img PATH] where PATH is the URL of the image you want to include and it must be accessible publicly
