Quality of Modicon PLC and Motion Control
Has anyone used Modicon Premium or Quantum PLC/Motion controllers? On paper they will do the job we require but having only used Siemens and Indramat in the past I am not sure about the ease of use, flexibility or reliability of the Modicon range.
How does their programming environment compare to Step 7?
Any feedback is gratefully received!
RE: Quality of Modicon PLC and Motion Control
Step7 is far better than concept.... I have used both. I will try to find more time later to go into detail. If I were you call your local dist. and get a demo copy of Concept and see for your self. Also Concept is Very expensive. Unless your customer has Modicons already push them to S7.
I'll grab a Demo of Concept, strange that Schneider are usually quite reasonable when it comes to software costs, Siemens are usually the ones charging through the nose.
Paul Thomas
