Calculations on shear stress - round rupture disk
Can anyone refer me to a service/company that can help on calculating shear values on a rupture disk or is anyone willing to do the calculations!  Math is not my best subject and I am trying to figure how to determine the material thickness in a one piece rupture disk design (I know it will be an approximate value and I can not use an existing rupture disk out there in the market).  The disk is .875 in diameter and is made from 316 stainless steel.  The disk is flat and the .875 is where the rupture will take place.  Question is how thick does that disk have to be to burst at 1000 psig @300°F.  I am also looking for the same answer at 2000, 3000, 4000 and 5000 psig.  If the calculation can not be made at 300°F then I can also use 72°F.
Thanks for the help.
RE: Calculations on shear stress - round rupture disk
fafaguchi:
 Refer to "Roark's Formulas for Stress and Strain" by Warrren C. Young, Printed by McGraw-Hill
There are formulas for circular plates with uniform pressure and fixed edges. The formulas are too extensive to duplicate them here.
Try Fike Corp (www.fike.com) they fabricate this type of thing for a living.
"I can not use an existing rupture disk out there in the market"
Why? They are an engineered and tested product.
An untested rupture disk is useless and un-safe.
