lightening existing beams
I am looking for any available reference regarding removing material (most likely circular hole sections) from a steel I beam that exceeds the needed capacity. Weight is an issue in the design of a platform structure, and I am seeking to lighten the existing beam by cutting sections out of the web. The load capacity can be reduced, but the reduction of capacity must be known. Any info as to hole shape, size, spacing etc. would be greatly appreciated. Thanks.
RE: lightening existing beams
It may be possible to replace the beam w/ a lighter one and be less expensive. Still expensive though.
Hire a structural engineer and discuss the parameters you need for the design. I seriously doubt, when taking platform live loads into account, the weight of the beam will be an issue.
Just my 2 cents
www.smisteelproducts.com
