check valves for end of pipe
I am looking for a website for info regarding check valves for the end of a storm line.  I guess it is similar to a tide gate.  The pipe is RCP. Thanks.
RE: check valves for end of pipe
Waterman manufactures flap gates which may work.  Manual or motorized slide gates may also be a good solution
http://www.watermanusa.com/Accessories.htm
I have used RedValves. they are designed for any head you want release or hold. There are no parts to mauntain and easy to install.
