PED Allowable stresses
Hi
I would like to here of other peoples' experience on the use of PED design stresses , ESR 7.1.2.
At present I use these stresses and the required joint coefficients only for shell internal pressure calculations, as these are the only general membrane stresses. For local load,external pressure, flat end, saddle and nozzle reinforcement (away from seams) etc. I use those design stresses from the particular design standard specified - mainly PD 5500.
Recently a colleague has told me that HSB insist on the use the ESR stress for all calculations but I can see no justification for this restriction.
This seems a fundamental area and any comments are greatly appreciated
RE: PED Allowable stresses
For this case you don't find coefficient in PED (PED isn't a code) so you had to apply the harmonised standards or a recognised code.
Section 7 of the ESRs is not mandatory, as long as you can show you have considered the risks adequatley. Whenever you use a design code it is my conclusion that you used the allowable stresses AND hydrostatic test pressure in accordance with the code.
It seems that I have been conservative, using the lower of PED or code stress for internal pressure.
My colleague spoke to HSB and they now seem to be in agreement with the 'whole code' method but they insist that the test pressure must be at least that given in ESR
It is unsafe to set the test pressure to anything but that dictated by the code. Each code contains shape factors and factors of safety that aren't always clear. When you use the test pressure defined by the code you ensure that you never exceed 90% of yield during the test.
I would argue this point, otherwise the only safe method is calculate the test pressure in accordance with section 7 of the ESRs and then back track to find what design pressure, according to the code, would generate such a test pressure.
Then design the vessel, using the code, to that pressure. I would think that, in most cases the "new design pressure" would exceed the required design pressure. However, this creates problems when it falls below the required design pressure (though I have never seen it happen).
I use a similar technique when designing a vessel for Japan using PD5500 or ASME VIII. The high pressure gas law in Japan requires a HTP of 1.5xDP as a minimum, so we calculate an effective design pressure to use PD5500 or ASME VIII.
I received from our notified body a copy of the Annex Z to ASME VIII - 1 where they claim :
"the manufacturer must use the test pressures specified in ยง7.4 of Annex I for the hydrostatic test. (Note : the hydrostatic test pressure of 1.3 in UG-99 of the code does not meet the PED requirement".
I was obliged to review my calculation accordingly.
The other code requirement remains applicable.
here is the extraction from the essential safety requirements:
3.2.2.
Final assessment of pressure equipment must include a test for the pressure containment aspect, which will normally take the form of a hydrostatic test at a pressure at least equal, where appropriate, to the value laid down in 7.4.
The importnant part of the statement above is "... where appropriate...".
Every one I have spoken to so far agress that it is not appropriate to step outside the bounds of the design code and that the same level of safety can be maintained by using the test value derived from the design code.
I've spoken further with my Notified Body and they don't agree with this, so I don't know where the decision has come from.
They direct me straignt to guidelines 8/6 and 9/5 (see the PED website link in the FAQs).
To the best of my knowledge the only NB that agrees with this stance is Lloyd's Germanische; Lloyd's UK and TUV both take the line I've proposed above.
We recently had a job the had to carry a U-Stamp and comply with the PED, we stuck rigidly with ASME VIII Div.1 and this was agreed by the AI and NB.
Who is your NB (if you don't mind me asking) ?
In the guidelines 8/6 and 9/5 there is nothing that support or contradict what was said. 8/6 concerns the achievement of an equivalent overall level of safety for exceptions to rules and sent back to 9/5 that speaks about alternatives to harmonized standard. Note in the last sentence "the use of a "recognised" code is not, in itself, sufficient to demonstrate an equivalent overall level of safety". The documentation had to be inspected.
Our NB sent us warning in this sens (U stamped tank is not sufficient, documentation had to be assessed regarding the directive). In the other hand they sent us a list of comparison between the annex I and the ASME VIII div.1 (Annex Z) where they show the considerations when applying this code. I can e-mail it to you if you send me your address.
I have U stamped equipment that I can't sell because the manufacturer doesn't want to send the documentation. With dollar low I am considering my position.
Our NB is AIB "0026".
I would like a look at it, my Email is guy@glowndes.freeserve.co.uk
Cheers
fawkes
As promised, I send you an excerpt from Annex Z (Additional considerations for application of section VIII, division 1 vessels within the scope of PED 97/23/EC, Annex I). In July we have had an expected visit from our notified body. Again we had a sulphurous discussion concerning the hydrotest. Normally according to PED we have to consider the temperature in evaluating the test pressure. According to ASME Test pressure = 1.3 P Sr/St (P: Maximum allowable pressure or design pressure, Sr : allowable stress at test temperature, St : allowable stress at temperatue). According to PED, Test pressure = max (1.43 P, 1.25 P fa/ft) where fa : allowable stress at test temperature and ft : allowable stress at temperature (Note that : 1-allowable stress in EN standards are before safety factor while in ASME II are with safety factor. 2-There is a guideline specifying this test pressure). As we have lot of product and customers asked product with his own design pressure it's hard for us to specify test pressure for each case because the system will become very heavy to acheive jobs, I do a study to compare the both ASME test pressure and PED test pressure to 1.5 P (which is our standard) and it appears that this one is the greater. The problem is that I had discussion in the past with the NoBo concerning calculation in test conditions. I told him that normally it's not required by ASME VIII div.1 and practically the stress had not to exceed 90% the allowable stress. He reject the argument and obliged us to do calculation in test conditions (for flange Appendix 2 with pressure of 1.3PSr/St) because "the equipment had to be checked in all forssen conditions".
Now the problem he asks us to revise the calculation in test conditions with pressure of 1.5 P. He's right but many years ago I heard that when applying a code It had to be entirely. But here we apply ASME with PED formula and it gives a strange mix !
Best regards,
It is worth noting that Merkblatt and Stoomwezen are the only codes I have ever used where a test pressure calculation is required.
You are quite correct, that if you calculate the test pressure in accordance with the code then it will not stress the vessel more than 90% of yield during the test.
Our notified body is also our AI for ASME and I've asked them about this again just recently, they still inform us that we stick to the code without deviation.
This means that the notified bodies aren't all singing to the same hymn sheet.
I'll check my Email tonight, thanks in advance for the info.
Fawkes
