Convert existing object in Dwg to blocks
I want to use the windows or crossing command to convert several hundred circles (fire sprinklers) on a drawing to individual blocks, that are all the same, so that I can use the "count" command to get an accurate count of fire sprinklers in a warehouse
RE: Convert existing object in Dwg to blocks
;COMMAND:  SPRINKLER
;FOR ALL VERSIONS OF AUTOCAD
;SAVE AS sprinkler.lsp to directory \SUPPOTRT\
;and from command line: (load "sprinkler")
;then, on command line, type SPRINKLER AND FOLLOW SELLECT-OBJECT PROMPTS
;ERASES ALL PICKED CIRCLES AND REPLACES EACH WITH A CIRCLE BLOCK OF R=100
;SCALED TO THE RADIUS OF EACH ERASED CIRCLE
;AND INSERTED AT ITS CENTER POINT,
;APPEARANCE REMAINS THE SAME BUT NOW CIRCLES ARE BLOCKS
;RICHLY COMMENTED FOR YOUR CONVENIENCE AND MODIFICATIONS
;FOR QUESTIONS please call at:
;www.homescript.com
;I am home most of the time.
;Get circles by any method you like - follow prompts to get objects
;only circles will be taken seriously, others will be ignored
(defun C:SPRINKLER()
;this allows select objects by any way you like
;first big IF
(IF (setq sset (ssget (list  (cons 0 "CIRCLE"))))(PROGN
;this tells how many circles were caught, picked, windowed, crossed
(setq ssetl (sslength sset))
;just for information, to see the circle count on command line
    (print ssetl)(princ " Circles found...")
  (circlo)
    (setq i 0)
  (while (< i  ssetl)
        (setq Edna (ssname sset i))
    (setq Eddy (entget Edna))
            (setq    Typy     (dxf 0 Eddy)
            ; this is not really used. Was for debugging
              Insy     (dxf 10 Eddy)
            ; Insertion point of circle we are going to erase
                  Rady    (dxf 40 Eddy)
            ;radius of circle we are going to erase
        ;this is tricky  (x Y) = (10 20) will be converted into "10,20"
        (setq Insy (strcat
                 (rtos (car Insy) 2)
                 (rtos (cadr Insy))
        ;remember, the block CIRCO has radius 100. Why not 1?
        ;well, snap complications I suppose - too tiny
        (setq rady (/ rady 100))
        ;and this converts R= 25.5 into "25.5"
        (setq rady (rtos rady 2))
        ;this was for debugging. Don't need anymore
          ;(print Insy)(print Rady)
        ;erase the circle
        (COMMAND "_erase" Edna "")
        ;insert block circle  with scale factor
        ;to correspond to radius of erased circle
        (COMMAND "_insert" "CIRCLO" Insy rady "" "" )
    (setq i (+ 1 i));NEXT CIRCLE
   );while ends here
  )(print "No Circles Found!" ));first big IF ends here
  (princ);suppress repeated prompt
);end of main function
;THIS makes a block of r=100 circle, if it does not exist IN THIS DRAWING
(defun Circlo()
(setq Blocky (tblobjname "block" "CIRCLO"))
(if (not Blocky)(progn
    (command "_circle" "0,0" "100")
      (command "_block" "CIRCLO" "0,0" "_L" "")
      ;(command "_erase" "_L" "")
;Useful function to extract-
;Entity name "CIRCLE n= 0
;Insy InsertionPoint n= 10
;rady radious        n= 40
;ed is full entity data
(defun dxf (n ed) (cdr (assoc n ed)))
