Pump Around Duty
Pump Around Duty
What is the most effective way to improve fractionation in Distillation tower (Crude tower), is to increase the PA return temperature or / and to drop the PA flow rate in order to lifting of material below the PA section to improve Freeze as an example?
RE: Pump Around Duty
An increased (normally 3-5% vol. on crude) overflash, i.e., heating coil outlet temperatures, could also be used to increase vapour loads.
Internal reflux is used for fractionation (ASTM gaps) by condensing upcoming vapours. This internal reflux is generated by the external pumparound, which is normally fixed by the heater's outlet temperature. Other heat is removed by the product streams. Temperature and (side-strippers) stripping steam rates are then the variables left to meet the heat balance requirements imposed by the overflash.
Besides, if the tower section washed by the pumparound is not trayed but packed, it is important to keep an efficient liquid flow rate for good spray distribution.
When you say "freezing" do you mean pour point ? If so, do you know for sure where the waxy paraffinic components are concentrated ?
