Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
bahram (Electrical)
25 May 03 11:35
As far as I know, there is no specific guideline in NEMA CC1-2002 for selecting the number of bolt holes for a terminal connectors. It only introduces the typical configurations in Appendix A.
As it is clear, the number of bolt holes is related to the rated current of connector. Is there any specific instruction in this regard?
What is the standards recommendation for a terminal connector with current rating of 1600A and 2500A.
jbartos (Electrical)
26 May 03 3:23
Suggestion: Contact NEMA since it is not currently shown on NEMA web:
http://www.nema.org/help/titles.html
http://www.nema.org/help/docno.html
RajT (Electrical)
26 May 03 8:45
I don't think there are any atandards as such. It is more of a question of engineering judgement. For high current ( say 1000A plus) lugs, one should allow for 4 bolts subject to adequate spacing between hole centres.
jghrist (Electrical)
26 May 03 11:18
NEMA requires connectors to operate cooler than the conductor in a standard heat run test.  For normal operation, you should be able to use whichever connector is listed for the conductor you are using.  If you are designing to run at high conductor temperatures, however, I'd use a larger connector (more bolts).  The more area on the connector the better.
Close Box
Join Eng-Tips® Today!
Join Us             Close
